9 Users Online (7 Members):
Forums >> Revit Building >> Technical Support >> Window wont place in wall of different thickness
So check this simple revit file. I have a window that I have made, for the first time it wont place in a wall of diferent thickness. If I change the wall thickness in the librry part, I can get it to go into the other wall, but then it doesnt go in the previous wall. I have the thickness of the frame locked to the wall thickness...but I can not figure this out. some one help me figure this out please! Screen shot shows error message. included revit file and library part. Michael
There is a problem with the constrain in one of your elements, is the highlighted one. Remove the actual constrain, go to sketch mode in that extrusion, and add there the constrains. Press tab to get the actual points and lines of the extrusion selected... be careful with that.
window thickness |
Thu, Dec 8, 2005 at 5:16:03 PM
Revit 2013 - Window frame sweep with wall thickness |
Wed, Nov 28, 2012 at 4:03:26 AM
Door wont cut into in place model wall. |
Mon, May 3, 2021 at 10:21:46 PM
Variable Thickness Wall? |
Fri, Feb 10, 2017 at 6:09:58 PM
Wall Thickness in Type Parameter |
Fri, Jun 1, 2018 at 7:39:15 AM
