11 Users Online (9 Members):
Forums >> Revit Building >> Technical Support >> How to make a "Model in-place" a "Family"
Hi I drew a "Model in-place" object in my project, then copied it 5 times for differenet places in the same project. However I found that they became 5 families in my schedule (Object 1, Object 2, Object 3......) In other words, if I change something in Object 1, all the other objects will not be changed..... How can I make a "Model in-place" a "Family"? Thank you
I don't have revit here right now but try this: edit that "In-place" then copy several times, finish the edit mode and check. "How can I make a "Model in-place" a "Family"?" - You can't, what you can do is create a "Group" with that in-place and save that group, then you can insert that group in other project.
Thank you very much :-)
Something else you can try is starting a new family, editing the in place family in your procject, then doing a copy/paste into your new family. Save, then load into your project.
I forgot that way Tkennedy, very good, I start to get old....
"I forgot that way Tkennedy, very good, I start to get old...." ......
changing the "family" and "type" names |
Mon, Apr 2, 2007 at 5:33:49 PM
tagging by "family name" and "family type" |
Mon, Jun 1, 2009 at 8:54:54 PM
Ceiling Plan tags in Linked Model Views "Moving" (2010) |
Tue, Dec 21, 2010 at 7:20:58 AM
How do you change a "generic model" family into a "mechanical equipment" family? |
Fri, Apr 6, 2018 at 6:18:19 PM
model: column-"properties" dims not scaling to whats shown on drawing |
Fri, Dec 12, 2008 at 3:10:11 PM
