Forums >> Revit Building >> Tips & Tricks >> Imported object transparent faces
Tue, Mar 15, 2011 at 3:28:31 AM | Imported object transparent faces
ibaifer
Good morning!
I´ve got imported several sketchup files, and I thought I´ve done all the steps right:
-First I´ve separed in layers all the materiales in Sketchup.
-I exported to dwg
-I imported the dwg file in Revit and I asigned materials by layers.
But I´ve got a big problem. The faces of the imported object are no showed, although they appers right in renders. Someone can help me.
Thanks.
Tue, Mar 15, 2011 at 6:02:56 AM | Imported object transparent faces
4 Stars: 205 Votes
Can you put some screenshots so we can see what's the problem? BTW, if they appears right in renders that's because you assigned the right material to that layer.
Tue, Mar 15, 2011 at 2:17:13 PM | Imported object transparent faces
ibaifer
As you can see in the image, the contour lines appear right and they´ve got colours (and materiales) but the faces are white, maybe I´m wrong and with imported object this is not possible.
Tue, Mar 15, 2011 at 2:33:44 PM | Imported object transparent faces
4 Stars: 205 Votes
That depends how the model was created and the materials and colors you apply to thosefaces, try to change the "visual style" and check if they change, but if the model is rendering well you have what you need.
Tue, Mar 15, 2011 at 2:44:52 PM | Imported object transparent faces
Did you assign a shading color to those materials?  Manage tab - materials.
Transparent object
Tue, Sep 14, 2010 at 1:18:34 PM
Transparent rendering
Fri, Jun 6, 2014 at 7:15:57 AM
Imported SAT models are semi transparent
Mon, Oct 25, 2010 at 7:42:05 AM
Autocad MEP Import Transparent Materials
Mon, Mar 21, 2011 at 11:18:59 PM
Problems with materials, lines and patterns of imported objects!
Tue, Jul 21, 2020 at 2:55:40 AM
Page generation time: 0.2031
