12 Users Online (10 Members):
Forums >> Revit Building >> Technical Support >> How to model a window from dwg file?
Hi I imported a pyramid-shaped skylight window from Autocad. I tried to import this dwg file to "family", and chose "metric window", then up load it to my project. This maybe work, but it can not be schedule properly....... What is the best way to model it in Revit since all the frames and glass are not regular forms? Thank you :-)
Don't do that, Autocad or Sketchup files are "Dumb" objects, you cannot manipulate them in Revit, so, read the tutorials and create your window like you want: http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=13376394
Thank you very much :-)
model a window in revit from dwg |
Sat, Apr 4, 2009 at 6:03:34 AM
Revit Not Cutting Through Imported .dwg 3D Model |
Mon, Jan 19, 2015 at 2:05:11 PM
Importing Sketchup file as dwg |
Mon, Oct 28, 2019 at 12:12:18 PM
How to show a correct section of a linked dwg model |
Wed, Sep 18, 2013 at 8:08:10 AM
DWG and Filled/Masked Region??? |
Thu, Jun 7, 2012 at 2:18:16 PM
