Forums >> Revit Building >> Technical Support >> MASSING
Mon, Mar 14, 2011 at 6:33:31 PM | MASSING
jaz321
HEY
I AM TRYING TO MAKE WINDOW SURROUNDS LIKE THE SILVER ONES IN THE PICTURE ATTACHED, I HAVE TRIED CREATING THEM WITH IN PLACE MASS STARTING WITH THE BOX TEMPLATE AND ALTERING IT, HOWEVER I DONT THINK THIS IS VERY ACCURATE....IS THERE ANY SPECIFIC WAY IN WHICH TO CREATE THEM? I AM USING REVIT ARCHITECTURE 2011...
THANKS
Tue, Mar 15, 2011 at 10:09:41 AM | MASSING
pchan
pchan Avatar
5 Stars: 5 Votes
Did you mean the surround on the left of the image?
Try to create a face based/ wall based family (generic catagory) and use it.
You can use simple extrusion to do it.
Tue, Mar 15, 2011 at 11:43:41 AM | MASSING
christofur84
4.5 Stars: 5 Votes
Try creating a sweep hosted on the windows opening.  Use this profile
http://revit.autodesk.com/library/archive2009/Library/Revit%20Architecture%202009%20Library/US%20Library/Families/Profiles/Trim-Exterior-Flat.rfa
@berriosdesigns
Tue, Mar 15, 2011 at 11:59:51 AM | MASSING
pchan
pchan Avatar
5 Stars: 5 Votes
Christofur84,
Did you mean to use this profile to create a in-place family?
I would think using a loaded family is a better way in this case sinceyou can make it as a parametric family and be able to use it for other projects.
and creating a loaded generic family is quite easy in this case.
Tue, Mar 15, 2011 at 12:07:36 PM | MASSING
christofur84
4.5 Stars: 5 Votes
Problably would be better for future use....i was just going for the quick fix...model in place...generic model...the sweep becomes somewhat parametric if you change windows sizes
@berriosdesigns
Tue, Mar 15, 2011 at 12:44:22 PM | MASSING
I would suggest that you don't use a mass for elements like this.  For both in-place families and loaded families, you should model the item in the correct category.  If this is a wall element, then you would want to place it in the wall category so that it can be controlled in VG.
Tue, Mar 15, 2011 at 6:47:33 PM | MASSING
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
I would also model in place.  A sweep in the wall category with "pick 3D edge" to define its path, the path being the wall edge where it's cut by the window.
Thu, Mar 24, 2011 at 8:28:49 AM | MASSING
jaz321
THANKS GUYS
I ENDED UP DOING IT WITH A REGTANGULAR MASS AROUND THE WINDOW FRAME EXTRUDE IT, THEN OFFSET THE MASS AND EXTRUDED IT AGAIN...WORKED BRILLIANTLY
THANKS FOR ALL YOUR HELP
Thu, Mar 24, 2011 at 9:11:43 AM | MASSING
My only comment is why a mass?  I can never understand why someone would use a mass rather than a true component element assigned by category.  If this should be part of the wall then make it be in the wall category - not mass.
Thu, Mar 24, 2011 at 10:31:01 AM | WWHub
4 Stars: 205 Votes
Quoting WWHub from 2011-03-24 09:11:43
Ditto
why my massing can't not be a solid?
Fri, Feb 11, 2011 at 8:26:42 PM
Massing
Mon, Jun 22, 2009 at 9:18:46 AM
conceptual massing...undulating roof shape
Thu, Jun 24, 2010 at 3:01:55 PM
Finding Massing Model
Wed, Feb 23, 2011 at 3:54:53 PM
>>>stuck with creating massing form in revit<<< HELP!
Fri, Nov 6, 2009 at 4:07:53 PM
Page generation time: 1.3526
