Forums >> Revit Building >> Technical Support >> Potlight Symbolic Lines showing up on other RCPs
Mon, Mar 14, 2011 at 2:27:19 PM | Potlight Symbolic Lines showing up on other RCPs
salam
Even with the view range adjusted to not even overlap other levels, the symbolic lines of my potlights (which are basically crosshairs) are showing up on other floor RCPs, and I can't figure out why. This also happens when I change the crosshairs to model lines, as far as I can see. Any ideas on why this is happening?
Mon, Mar 14, 2011 at 2:41:29 PM | Potlight Symbolic Lines showing up on other RCPs
Check for a vertical hidden line in that family.  If there is a hidden line in your potlight family that crosses into the other view's range, then this family will show.
Symbolic Lines and Model Lines
Wed, Mar 22, 2006 at 12:52:17 PM
symbolic lines
Thu, Jul 13, 2006 at 8:15:41 PM
Windows above the Cutplane and Symbolic Lines (Revit2010)
Wed, Jul 14, 2010 at 7:35:42 AM
Symbolic/Model lines bug!
Wed, Oct 21, 2009 at 1:39:23 AM
Oblique Symbolic lines
Thu, Jan 1, 2015 at 3:47:42 PM
Page generation time: 1.3667
