11 Users Online (9 Members):
Forums >> Revit Structure >> Technical Support >> Wood Roof Bracing Problems
28 Posts No Rating |
I am new to Revit and currently usuing Structure 2011. I appologize if the answer to my question is obvious, but I couldn't seem to find a solution elsewhere. We do a lot of residential frame design. I am looking for the best way to add braces from wall to roof and the best way to have those braces show up in my level views. Any help is much appreciated. Thank you, Dave
I forgot to mention that we ar currently using slanted columns to represent the braces. It seems easy enough but does not allow us to show where the column connects to the roof or the wall very well.
Revit 2014 Vertical Bracing Problems |
Thu, Feb 20, 2014 at 10:26:00 AM
Rotation angle of double angle roof bracing. |
Mon, Jan 21, 2008 at 2:51:55 PM
Bracing Shedules |
Thu, Aug 27, 2009 at 2:53:25 AM
Pre-manuf. wood roof trusses |
Tue, Dec 19, 2006 at 3:14:08 PM
Wall Bracing (plywood sheets) |
Sun, Aug 19, 2007 at 7:04:04 PM
