Forums >> Revit Structure >> Technical Support >> Pile Cap Hidden Line Issues
Sun, Mar 13, 2011 at 11:22:53 PM | Pile Cap Hidden Line Issues
mfleming
Hi, I'm trying to build a new pile cap /w pile in a single family. Meaning, I'm doing the extrusions in one family rather than nesting the pile. For some reason, I cannot see the hidden lines of the piles this way, even if I put the View Range well below the pile cap, I still see only the pile cap itself. Pile Cap Family Properties: Cap = N Shared = No Family Category = Structural Foundation Family Parameters -->Structural Material Type = Concrete I have two images attached comparing the out of the box pile cap and my "working" pile cap without the nested piles. Does the piles have to be nested to show up hidden? Any suggestions? My last resort would be go back to nested pile but....
Mon, Mar 14, 2011 at 10:27:06 AM | Pile Cap Hidden Line Issues
gregroberson
gregroberson Avatar
You are always going to want to see the projected lines of the pile as hidden right?  Have you tried making the lines in the extrusion as hidden?
Mon, Mar 14, 2011 at 7:26:58 PM | Pile Cap Hidden Line Issues
mfleming
I added some symbolic lines and locked them to the pile.
This seems to work in my tests, I'll see if it works on my project properlly next.
Wed, Apr 20, 2011 at 9:31:16 AM | Pile Cap Hidden Line Issues
JayZee
Providing the view range is set correctly, make sure you tick the ‘Shared’ Option under ‘Family Category and parameters’ for the pile itself. Also set a material to concrete or precast concrete if you wish it to match the cap/footing. Save the RFA and load it back into the project.
 Also, set your scale to 1:20 in the project so you can see the hidden line dashed detail.
Hidden line issues
Fri, Feb 13, 2009 at 7:59:38 AM
Pile cap issue
Thu, Jun 3, 2010 at 7:22:27 AM
Snazzy Pile Cap Family
Wed, Aug 27, 2014 at 2:35:17 PM
Visibilty
Fri, May 9, 2008 at 3:42:38 PM
Revit 2013: Wierd family issue...
Thu, Jun 20, 2013 at 11:28:33 AM
Page generation time: 0.4308
