Forums >> Revit Structure >> Technical Support >> Imported .dwg File Visibility Settings
Sun, Mar 13, 2011 at 10:02:41 PM | Imported .dwg File Visibility Settings
raja15
I have imported a surveyor's plan into revit via File > Import/Link > CAD Formats, and it has been placed on the appropriate level in relation to the site levels.
I was wondering if there is a way to bring the imported symbol to the foreground of all views, but without editing any of the level properties which need to remain as is.
Mon, Mar 14, 2011 at 10:25:26 AM | Imported .dwg File Visibility Settings
gregroberson
gregroberson Avatar
You may be able to set it as an underlay in the view property settings once you have the dwg. "locked" to a view?
Mon, Mar 14, 2011 at 5:29:06 PM | Imported .dwg File Visibility Settings
raja15
Thankyou very much Smile
imported DWG visibility
Fri, Apr 13, 2007 at 12:26:22 AM
Annotations accidentally snapped into linked dwg (Imported categories)
Tue, Jul 9, 2013 at 5:53:11 AM
Imported dwg files
Wed, May 10, 2017 at 10:25:29 PM
imported dwg lineweights, linetypes
Fri, Aug 10, 2007 at 9:22:53 AM
3D DWG as a Mass - Visibility Problem
Fri, Sep 5, 2014 at 1:30:53 AM
Page generation time: 0.6803
