Forums >> General Discussion >> Revit Project Management >> Window Family...
Sun, Mar 13, 2011 at 1:42:23 AM | Window Family...
looli
Hello! I am new to Revit. I have some questions concerning the window family I have created in Revit:
1.) The window is placed on the reference level (0.00). As you can see in the 3D view (attached image) the bottom frame extrudes into the minus level which means it also interacts with the floor (attached section image) - the frame mounts down to the core boundary of the floor structure. So the window is not only wall hosted but also floor hosted. It should be placed the void form in the floor to make the frame visible in the section view.
Is it possible to add the floor host to the window family and how?If not, how to make the frame visible in section view of the project?
2.) As you can see in the floor level view (attached image) the window is placed into the composite wall called Isorast (passive house). The interior and exterior insulation layers wrap on the left and right frame as needed. However, in the section view the top frame is not wrapped at all. It should be wrapped the same way as the left or right frame.
Is it possible to wrap the top frame and how?
3.) The grids I use in the project are half toned. I would like them to be placed behind the geometry.
Can we send them to back (like in the Autocad) and how?
Thank you!
Edited on: Sun, Mar 13, 2011 at 1:57:31 AM
Edited on: Sun, Mar 13, 2011 at 1:58:02 AM
window frame family + nested window frame fill
Wed, Apr 12, 2006 at 7:31:30 AM
Imported family not flexing in window family
Thu, Jan 31, 2013 at 7:21:53 AM
Window Legends-showing nested components
Thu, Mar 20, 2008 at 4:20:36 PM
having trouble with window rfa
Mon, Sep 8, 2008 at 10:37:11 AM
basic window family tutorial(step by step)
Mon, Sep 6, 2010 at 7:26:53 PM
Page generation time: 0.9376
