Forums >> Revit Structure >> Technical Support >> creating a label to call up project parameters
Fri, Mar 11, 2011 at 2:17:14 PM | creating a label to call up project parameters
TimStephenson
TimStephenson Avatar
I am trying to make a label that can be used within a drafting view that well call up information in the project parameters. I know that it needs to be a shared parameter. Want to be able to place the label on a body of text. If i make a tag it needs to attach to a element and doesn't work because I don't have anything to tag.
Fri, Mar 11, 2011 at 3:21:05 PM | creating a label to call up project parameters
Then make something to tag!
Think .... invisible detail family.  <  Exactly just that.  An invisible line in a detail family.
New Title Page Label Using Project Information
Sat, Feb 10, 2018 at 11:54:48 AM
Using alle the project parameters in label (not shared parameters!
Fri, Nov 30, 2012 at 7:23:04 AM
Cannot Edit Label After Inserting into Project
Fri, Sep 14, 2012 at 7:07:14 PM
Titleblock Parameters [ 1 2 ]
Thu, Mar 13, 2014 at 4:57:53 PM
17
Sheet Label to Drawing List
Fri, Sep 9, 2011 at 2:56:26 PM
Page generation time: 0.6637
