Forums >> Revit Building >> Technical Support >> dropping tree on topography
Fri, Mar 11, 2011 at 4:52:50 AM | dropping tree on topography
joewallace
i have a large site with a big change in levels and im wondering is it possible to just 'drop' trees onto the site so they land on the toposurface so that i dont have to change all the levels on each tree
thanks
Fri, Mar 11, 2011 at 12:42:46 PM | dropping tree on topography
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
depends on the tree, whether it is surface hosted or not. best trees prolly http://sketchup.google.com/3dwarehouse/
Mon, Mar 14, 2011 at 10:39:40 AM | dropping tree on topography
joewallace
what about the trees already in revit, im using 2011. is there a way of making them surface hosting?
Thu, Apr 26, 2012 at 8:22:49 AM | dropping tree on topography
albionarchitect
Revit planting families automatically sit on top of the toposurfaces, so you just place them over the plan. It's important that elements in the planting family plan view are done properly with symbolic lines always visible, otherwise the tree circle goes into the terrain. We are using families from <a href="http://www.archigrafix.com">archigrafix</a> since I think they are a bit better than the ones that are default on revit. But trees in revit also sit directly on top of toposurfaces if you want to use them.
Thu, Apr 26, 2012 at 5:45:26 PM | dropping tree on topography
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
when you have a tree selected, there should be a big green icon on the right side of your toolbar that says "pick new host."  All tree families I can remember using where able to do this.
Tree
Fri, Jul 16, 2010 at 4:19:25 AM
rpc tree
Tue, Mar 31, 2009 at 12:01:03 PM
tree render
Mon, Oct 13, 2008 at 2:12:37 PM
Cannot Edit Tree Height
Thu, Oct 3, 2013 at 1:38:21 PM
shifting CAD plan
Fri, Jul 18, 2008 at 3:53:47 PM
Page generation time: 0.4927
