21 Users Online (19 Members):
Forums >> Revit Building >> Technical Support >> File naming when plotting to PDF
Is there a way to specify how REVIT names files when plotting to PDF? When I do a batch plot of a bunch of sheets or even a single sheet REVIT will automatically name the files using "[File name] - Sheet - [Sheet number] - [Sheet title]". I would like to remove the "Sheet -" and also the "[Sheet title]" from the file naming and add the "- [Revision number]" of each sheet at the end. So it looks like this "[File name] - [Sheet number] - [Revision number]". Is this possible?
Thre is no way to do this in native Revit.
Google 'Bulk Rename Utility'. It's a free utility that will let you quickly do all sorts of renaming tasks.
You can now do this with the new Revit API addon - Xrev Transmit. Download the trial from the website.
Regards,
Chris.
25 Posts No Rating |
^ Good info - wasn't aware of that API addon. Thanks!
Palm Springs Architect using Revit LT! |
Plotting PDF's |
Tue, Jul 21, 2009 at 4:18:05 PM
Single sheet PDF Naming error |
Tue, Nov 23, 2010 at 7:18:24 AM
plotting problem |
Wed, Dec 22, 2004 at 3:44:51 PM
RVT 9.1 - plotting as PDF changes lines to halftone |
Tue, Jul 24, 2007 at 3:54:18 PM
plotting to a plotting service plotter with a prn file |
Wed, Jun 4, 2008 at 1:14:56 PM
