Forums >> Revit Building >> Technical Support >> when exporting from sketchup to revit - urgent problem!
Wed, Mar 9, 2011 at 3:08:53 AM | when exporting from sketchup to revit - urgent problem!
cookie4
Hello,
I have a problem and I need to solve it fast! so may b someone can help me
I did some plans in revit, then exported them to sketchup and worked on them there, after that, I exported them to a new revit file to continue working on the plans with the new sketchup things I've added, but the file I get in revit I get it as a block/group.
I'vve tried to unblocked it and ungroup it but I can't .
I cheked if in sketchup it was all a block or smething but I can't seem to work out where the problem is.
It's impossible to get INTO THE BLOCK either on revit so I can't work on the file at all in revit!
PLease! someone!!! HELP!!!!!! Smile
THANKS
JENNY
Wed, Mar 9, 2011 at 7:13:06 AM | when exporting from sketchup to revit - urgent problem!
coreed
coreed Avatar
4 Stars: 16 Votes
sorry, that file will never be a true Revit file again.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Wed, Mar 9, 2011 at 8:25:46 AM | when exporting from sketchup to revit - urgent problem!
pchan
pchan Avatar
5 Stars: 5 Votes
For future reference, you should never use this approach, you will end up doing things twice...
Sketchup model into Revit
Tue, Jan 8, 2013 at 12:06:20 PM
RENDERING PROBLEM NEED HELP URGENT...
Fri, Dec 4, 2009 at 8:00:12 AM
revit into sketchup
Sat, Dec 3, 2011 at 5:17:06 AM
Revit to Sketchup
Fri, Apr 18, 2008 at 5:51:30 AM
Sketchup to Revit material problem [ 1 2 ]
Wed, Jun 30, 2010 at 11:58:37 AM
26
Page generation time: 3.1653
