Forums >> Revit Building >> Technical Support >> Wall Legend - Some walls work in Section, others will not!
Tue, Mar 8, 2011 at 4:38:50 PM | Wall Legend - Some walls work in Section, others will not!
QueenBcp
I'm trying to make a Wall Types Legend using the Legend function in Revit Architecture 2011.  I did the first wall type just fine, placed it in section, tagged the material, etc.  Now when I go to place another wall in a section view, it tells me the component is not visible in selected view.  Thoughts?!  They are both new construction phase, stacked walls.I've been going nuts trying to find the answer online and it is making me waste a ton of time at work (thank you Revit for helping my productivity... oh, wait...)
Any help is appreciated!
Thank you,
C*
Wed, Mar 9, 2011 at 7:55:00 AM | Wall Legend - Some walls work in Section, others will not!
Stacked walls should never be placed in a legend because they are not a wall type really.  They are an assembly of wall types grouped together in a defined manner for easy placement.  You need to legend each portion seperately.
section tag in legend view
Tue, May 2, 2017 at 4:00:04 PM
wall legend questions
Mon, Jun 17, 2019 at 5:54:34 PM
wishlist - section tag in legend view
Thu, Mar 13, 2008 at 2:52:36 PM
Hiding Legend Notation
Tue, Jun 25, 2013 at 10:25:19 AM
Is there a way to force walls to show section?
Tue, Aug 4, 2015 at 7:40:31 PM
Page generation time: 2.7515
