Forums >> Revit Structure >> Technical Support >> Cut Geometry shows in 3D and Plan but not in Section?
Tue, Mar 8, 2011 at 4:12:49 PM | Cut Geometry shows in 3D and Plan but not in Section?
BrianS123
Hi,
I have used reference planes and the cut geometry tool to cut one beam to another.  It shows up great in the 3d view.  It does not show up in the section view.  However, if I nudge the section forward or backward in plan then there is a very brief time when the cut geometry beings to show.  However, it still does not show completely.  Does anyone know why a cut geometry would show in 3d view but not in section view?  Thanks for any suggestions.  I am using Revit Structure 2009.
Thanks,Brian
Fri, Nov 30, 2012 at 8:54:55 AM | Cut Geometry shows in 3D and Plan but not in Section?
Steelgolf
I'm having the same problem with a cut counter.  Looks great in 3d but the cut doesn't show in plan view.  Help.
Fri, Nov 30, 2012 at 9:09:32 AM | Cut Geometry shows in 3D and Plan but not in Section?
Steel - Your question is not the same and doesn't belong in the structure category
Please start a new thred.
Fri, Nov 30, 2012 at 1:44:30 PM | Cut Geometry shows in 3D and Plan but not in Section?
rbcameron2
rbcameron2 Avatar
4 Stars: 25 Votes
Have you tried changing the section view from course to medium to fine?
Also, open the family up and there should be a checkbox that says, "Cut family in plan" in the properties.  Uncheck that box, save and reload.
Those are my two quick suggestions,
RB Cameron
3D Medical Equipment
Download Revit Healthcare Models Now
Download Other Revit + 3dsMax Models Here
When I cut a section or elevation in revit, it shows what's behind the cut plane
Fri, Dec 6, 2013 at 12:47:17 PM
Cut Pattern in Plan vs Section
Tue, Aug 25, 2009 at 8:47:59 AM
Revit Architecture 2012 - Section shows view from behind cut line
Thu, Jan 10, 2013 at 12:38:20 PM
Section cut material shows up grey instead of brown
Mon, Apr 11, 2016 at 10:16:45 AM
I can't see wall with section lines eventhough cut plan passes through the wall!
Mon, Sep 15, 2014 at 9:42:29 PM
Page generation time: 7.6000
