Forums >> Revit Systems >> Technical Support >> Controlling A Circular Sweep
Mon, Mar 7, 2011 at 5:55:21 PM | Controlling A Circular Sweep
koolair
4.5 Stars: 2 Votes
Hi everyone,
I am having a problem with a round air diffuser.  I'd like to make different types defined by duct radius, or even just one type with infinitely varying duct radius, but the first option is better.
I have drawn a profile which I sweep around a circle.  I'd like to make the sweep radius a parameter.  Any ideas?
Hope to hear, and thanks in advance!
Joe
Tue, Mar 8, 2011 at 12:41:39 PM | Controlling A Circular Sweep
koolair
4.5 Stars: 2 Votes
I may have mis-stated my question.  Here is a picture to describe the problem (attached MS Word file).
I probably need to do this via revolve.  But the question will remain the same (I believe).  How do I control the size of certain geometries by parameters?
The dimension I want to parameterize is indicated on the attached.  Please if anyone can help, that'd be great news!
Tue, Mar 8, 2011 at 1:40:53 PM | Controlling A Circular Sweep
pchan
pchan Avatar
5 Stars: 5 Votes
Maybe something like this?
you can set parameter to the arc and control it by simple formula (i.e. R1 - 2" = R2)
and lock other lines to the reference plane. and you should be able to control the profile family
Philip
Tue, Mar 8, 2011 at 4:47:59 PM | Controlling A Circular Sweep
koolair
4.5 Stars: 2 Votes
Tue, Mar 8, 2011 at 4:50:49 PM | Controlling A Circular Sweep
koolair
4.5 Stars: 2 Votes
Thanks...I'll look at that again.  I tried this but I can't get the reference lines working while in sketch mode.
Sorry for all the repeat posts....I think it has to do with my refresh button.
Joe
Error Message: "Circular Chain of Reference" - help requested!
Thu, Nov 24, 2011 at 9:34:08 PM
creating mass through solid sweep
Sun, May 13, 2007 at 5:30:43 AM
Circular Arch
Tue, Jul 21, 2015 at 9:06:15 AM
Way around circular formuala references?
Tue, Nov 19, 2013 at 6:15:48 AM
13
Circular Beam
Thu, May 15, 2008 at 12:40:23 PM
13
Page generation time: 1.4290
