Forums >> Revit Systems >> Technical Support >> Backup Failed Error
Mon, Mar 7, 2011 at 12:25:49 PM | Backup Failed Error
RevitFTW
How do I fix this?  I created some families and saved them to our network.  I wanted to move the files to a different location on the network and now when I try and save them I get an error that says "Revit failed to back up the file before saving.  Check the available disk space before proceeding.  Are you sure you want to overwrite \\ file path\file name?"  There should be enough disk space, I don’t get why it says this...any ideas?
Mon, Mar 7, 2011 at 2:27:50 PM | Backup Failed Error
If you are moving them, then why are you using Revit?.... Just copy / paste the files from one directory to the other.
Mon, Mar 7, 2011 at 3:58:19 PM | Backup Failed Error
RevitFTW
I am.  when I open the files and save changes, that's when I'm getting the message.  It's saving my file, it just wont create the backup files.
Mon, Mar 7, 2011 at 4:05:08 PM | Backup Failed Error
Check out your network permissions for this locvation.
Wed, Mar 9, 2011 at 1:27:46 PM | Backup Failed Error
RevitFTW
I am the admin for that location.
Failed to open ducument
Tue, Aug 14, 2012 at 7:35:54 AM
Seek Failed
Wed, Aug 12, 2009 at 11:16:29 PM
Revit Architecture 2009 "failed to initialize"
Wed, May 20, 2009 at 3:08:21 PM
"Failed To Open Document" error
Mon, Dec 14, 2009 at 9:16:54 AM
Error message-Failed to open document
Thu, Apr 10, 2008 at 6:17:40 PM
Page generation time: 0.2907
