Forums >> Revit Building >> Tips & Tricks >> Grid based view titles for viewports
Sun, Mar 6, 2011 at 9:07:37 PM | Grid based view titles for viewports
Ryan0108
Hi all, I'm new to revit and this forum.  First I'd like to say thanks to everyone for contributing to these forums, they have helped me so much in getting a project up and running in revit...
 I am trying to find a way to customize the stock view title so that instead of being view numbers (1/A101, 2/101,...) I want them to be based on a grid we have established around our border sheet (1A/A101, 4G/A101...kind of like the game Battleship)
This has been our company standard in ADT and it would be nice to be able to continue this in Revit.
Thanks in advance.
Sun, Mar 6, 2011 at 9:30:36 PM | Grid based view titles for viewports
lunchtrayrider
3.5 Stars: 7 Votes
Have you tried changing the numbers yet?
I like scooters. and motorcycles.
Mon, Mar 7, 2011 at 7:48:40 AM | Grid based view titles for viewports
Ryan0108
Lunchtrayrider, thanks for your reply. I have tried changing the numbers manually and it works as it should.  I guess what I'm looking for is some kind of automated way that the detail numbers will update themselves basd on their position on the sheet.  The issue I'm having is as the project moves forward and we add/subtract/arrange/rearrange the details I have to update them manually before we plot.  It would be great if these numbers could update themselves based on our grid system as we add them and move them around the sheet.
Mon, Mar 7, 2011 at 10:10:13 AM | Grid based view titles for viewports
lunchtrayrider
3.5 Stars: 7 Votes
If you name them by the area of the sheet they are located you would only have to change the numbers when you move them :-)     As far as I know there is no way to do what your asking.  I also go through and update the numbers right before plotting.  (at least you don't have to update the tags in all of the views)
Mon, Mar 7, 2011 at 10:25:09 AM | Grid based view titles for viewports
They will number sequentially so if you do the first one at 1A, the second one will be 1B.... not what you want so it looks like you place on the sheet and change the number ..... just like you did in CAD.
No disadvantage, just not completely automatic.  However, the callouts will all still be numbered correctly everywhere they are shown so still an advantage over CAD.
snap to grid does not work for viewports
Fri, Apr 5, 2019 at 8:29:02 AM
Purge unused Viewport Titles
Thu, Aug 30, 2018 at 10:41:49 AM
11
Viewports orginizing on sheet
Mon, Apr 18, 2016 at 10:45:14 AM
Aligning Sheets (Titles, Viewports, ETC.) HELP!
Tue, Mar 11, 2008 at 1:25:09 AM
Grid Lines - Instance based text in grid line family
Mon, Jul 23, 2018 at 2:17:14 PM
Page generation time: 1.7573
