20 Users Online (18 Members):
Forums >> Revit Building >> Technical Support >> unable to add roof overhang
Not sure why, since switching to RA 2011, when I draw the footprint of a roof it's not letting me enter an overhang. Box is greyed out. Thanks
1 Posts No Rating |
The roof overhang needs to be setup when you construct the roof. You are not able to add in overhangs, if you did not set them up. When you create your roof set the overhang in the box that was greyed, then use the PICK WALLS tool to select the walls. A dashed line will show you the side of the wall that the overhang will go on. USe the pick walls tool on the sections that you want overhangs.
can't adjust roof overhang |
Mon, Feb 16, 2009 at 12:12:59 PM
Roof Overhang extension |
Fri, Feb 3, 2017 at 8:20:07 PM
Flat roof Overhang with profile |
Tue, Apr 13, 2010 at 9:59:56 AM
changeable Overhang thickness |
Mon, Oct 8, 2012 at 5:02:32 PM
Unable to Create Domed Roof |
Thu, Jan 8, 2009 at 11:31:53 PM
