Forums >> Revit Building >> Technical Support >> Curtain Wall Corner Mullions
Thu, Nov 10, 2005 at 11:27:17 AM | Curtain Wall Corner Mullions
MackAttack
I know how to creat a custom profile for a standard Mullion but is there a way to do it for corner mullions I don't see a profile under the properties in the coner mullion? If you could point me in the right direction it would be appreciated
Thu, Nov 10, 2005 at 11:24:13 PM | RE: Curtain Wall Corner Mullions
eldados
eldados Avatar
4.5 Stars: 8 Votes
that's right, you can't assign a profile to a corner mullion... you could play with a profile for a mullion and put it at the end, but it can't be a corner mullion.
Integrator
KarelCAD
Corner Mullions
Fri, Dec 6, 2013 at 11:05:58 AM
Curtain wall with splayed mullions
Tue, May 10, 2016 at 2:05:31 PM
Mullions at corner of curtain walls
Thu, Jan 21, 2016 at 10:52:07 AM
Problem with Curtain wall Mullion clean up at corners
Mon, Apr 7, 2008 at 9:53:09 AM
Curtain wall mullions
Fri, Jan 11, 2008 at 9:22:15 AM
Page generation time: 0.6426
