7 Users Online (5 Members):
Forums >> Revit Building >> Technical Support >> show hidden lines
209 Posts No Rating |
Its probably a simple answer but suddenly all my hidden lines showing objects behind others all dissapeared and i cant them to show again. Ive tried using the tool on them and they still wont reveal as hidden underneath i would assume its a visual setting. I tried reopening the project to see if it was just a program error and it isnt. Any help would be much appreciated.
Try wireframe view to see if they are really there. Are you in Drafting View, try Bring to Front if you have regions.
Motto: "No Post left behind" |
no regions, actual elements throughout hence using the show hidden lines tool. The elements are there in wireframe in fact when i go to print the elements show like they are supposed to as hidden lines but in actual view they dont show. Im guessing this could be a graphics card issue.
Create a new hidden linetype and assign a heavier pen width then subsitute that to your hidden line. If that shows up, it's your screen resolution.
How do i assign a heavier hidden linetype to an actual hidden object represented as hidden lines? Im not using the linework tool, im not using model or anotative lines im revealing the hidden element thorugh an object. How do i change that linestyle/weight.
Show Hidden Lines - Structural Foundations |
Thu, Jan 13, 2011 at 10:37:01 AM
Show Hidden Lines Tool and Detail Elements |
Fri, Nov 22, 2013 at 8:48:50 AM
Hidden Lines disappeared from all my Elevations |
Fri, Mar 1, 2013 at 12:37:04 PM
Hidden lines in elevations |
Mon, Sep 10, 2007 at 9:43:06 AM
Show Hidden Lines Creating Double Lines |
Mon, Sep 23, 2013 at 11:55:16 AM
