Forums >> Revit Building >> Technical Support >> Section view referencing back to a different floor plan
Wed, Mar 2, 2011 at 7:27:26 PM | Section view referencing back to a different floor plan
redbrick
Any ideas how a section view originating from a building floor plan, when placed on a sheet, refences back to a slab plan?
Thu, Mar 3, 2011 at 8:10:57 AM | Section view referencing back to a different floor plan
The section cut will refer to the first view it was placed on.  So someone renamed your slab-plan....
To fix, cut a new section in the sme place on your floor plan and copy paste annotations from the old section to this one.  Then delete.  NOTE:  The new section will still show in both views but the reference will be correct.
Sun, Mar 6, 2011 at 5:11:24 PM | Section view referencing back to a different floor plan
redbrick
Thanks for the help, I'll do just that.
Callout's in section view, referencing them in plan view
Tue, Jul 15, 2008 at 5:00:18 PM
Sections Referencing the drawing you want. Help Cheat!
Fri, Feb 25, 2011 at 11:22:05 AM
Changing Sheet References
Thu, Sep 18, 2008 at 12:23:06 AM
Two Way Referencing
Tue, Apr 20, 2010 at 7:01:13 PM
Label in Callout Floor Plan Tag
Tue, Dec 29, 2009 at 3:13:13 PM
Page generation time: 1.0014
