15 Users Online (13 Members):
Forums >> Revit Building >> Technical Support >> Wall Types and Materials are not shown in Revit 2011
2 Posts No Rating |
I downloaded the student version of revit 2011 and when i go to the "Wall" drop down menu i only get Basic Wall and Curtain Wall.... It does not have all of the other walls Cmu and brick, metal stud etc... Even when i go to edit the Basic wall and try to change materials for its structure there are no materials loaded...no concrete, wood etc. I have reinstalled the Autodesk material library and it still does not load anything that i have on my school computer ...i just dont know why its doing this? Does anyone know how to fix this issue?
5 Posts No Rating |
Hi
Have you fixed it out what happend ??? because Im having the same problem here as well !! please let me know it would help a lot .
thank you
may
Walls are system elements and Revit starts you off with a couple. You will need to either build on these creating your own types or find others on-line. Look at http://www.usgdesignstudio.com/ for some walls roofs and floors.
2 Posts No Rating |
i did fix it. my computer was not connected to the internet, thus when i installed the program Autodesk could not download the necessary wall types and families from its online database.
There is a way to do it offline, but its more complex.
May: try connecting your computer to the internet and reinstall revit.
hope that helps!
Wall Types |
Mon, Jul 16, 2007 at 9:27:03 PM
Wall materials |
Thu, Oct 12, 2006 at 6:52:15 PM
Walls - Incorrect tile shown - Revit 2011 |
Tue, Dec 14, 2010 at 4:05:33 PM
Line between different wall types in eleveation |
Mon, Dec 15, 2008 at 7:10:38 PM
Copy/Monitor Walls Creates Too Many Family Types (REVIT Structure 2011) |
Fri, Jan 14, 2011 at 1:27:26 PM
