Forums >> Revit Structure >> Tips & Tricks >> Worksets and Filters
Wed, Mar 2, 2011 at 10:32:41 AM | Worksets and Filters
amandaholly
Couple of Qlitches I found with filters by worksets
I had my site represented as modelling lines and cad inserts at my below grade level and upper grade level with each on there own I worksets (Site Lower and Site Upper).  I discovered that Filtering my worksets do not include lines and I wished to use the workset to halftone below.
Solutition:  Insert the lines into a family
The other issue is the filtering does not allow selection of more than one workset.  It is actually kind of stupid as far as how the programming is coded.  If you select Filter by workset 'Site lower' and Filter by 'site upper' it actually cancels out your first selection since objects cannot exisit on more than one workset; there should be a or that allows for more than one workset to be pulled through the same filter
Solution: Set up a sperate filter for each workset
Heating filters
Fri, Feb 12, 2016 at 11:03:41 AM
? about worksets and filters
Tue, Mar 1, 2011 at 4:36:31 PM
View filters
Fri, Jun 11, 2010 at 5:22:38 PM
Plumbing Switching between worksets
Tue, Aug 24, 2010 at 2:00:01 PM
View Filters and Linked Models
Tue, Mar 28, 2017 at 7:53:31 PM
Page generation time: 3.7144
