Forums >> Revit Building >> Technical Support >> plan shows as halftone - set to normal
Wed, Mar 2, 2011 at 9:55:19 AM | plan shows as halftone - set to normal
Binnsdrafting
Good morning all,
I'm sure this is a simple fix but I'm stumped how ot do it. I have a basement level that is showing walls and components as halftone even though the settings are "normal" but when I input an interior elevation is diplayed normally!!
It is all new construction (verified with each object), no phasing is used, it is very basic it is just displaying improperly. I'm using Revit Arch 2011.
As usual any help is greatly appreciated. Thank you for your time
BB
Wed, Mar 2, 2011 at 10:49:46 AM | plan shows as halftone - set to normal
DeifyMe
4 Stars: 2 Votes
Have you tried playing around with your View Range? Maybe the cut plane is above the walls...
Wed, Mar 2, 2011 at 11:14:26 AM | plan shows as halftone - set to normal
TKennedy
4 Stars: 8 Votes
Another thing to check is the discipline in the view properties.
Wed, Mar 2, 2011 at 11:32:51 AM | plan shows as halftone - set to normal
Binnsdrafting
Yes, I checked the view range and it is set for that level - Basement - and it is set at 4'-6" (top of walls is set at 7'-4"Winking
Discipline is set to Architectural.
All of the notes, dimensions, elevation tags, section tags, etc are displaying normally - just the walls and components show halftone!
Thank you for the suggestions - might you have any others? :-)
Wed, Mar 2, 2011 at 11:46:45 AM | plan shows as halftone - set to normal
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
I'd check the visibility graphics overrided and any overrides by category.
See two images attached.
Wed, Mar 2, 2011 at 12:20:05 PM | plan shows as halftone - set to normal
Binnsdrafting
Thank you dgcad - it was the "Halftone" checked in VG. Like I said, probably an easy fix (and I even looked in VG but apparently did not look at the entire screen).
Now the questions is how did those get checked? But the problem is fixed. Thank you again - If you were in the Denver area I'd buy you lunch.
Wed, Mar 2, 2011 at 12:28:07 PM | plan shows as halftone - set to normal
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
No problem . . . . I have a brother in Colorado Sprongs : )
Revit MEP 2012 - Halftone not Working...
Fri, Oct 5, 2012 at 12:47:21 PM
electrical plans
Sat, Feb 11, 2006 at 12:20:14 PM
Design Options Halftone?
Tue, Nov 20, 2018 at 10:58:56 PM
Ductwork in some views, when set to existing is not printing as halftone
Fri, Jun 7, 2019 at 4:46:47 PM
Imported CAD formats appearing halftone
Thu, Oct 18, 2007 at 1:44:50 PM
Page generation time: 1.2658
