Forums >> Revit Structure >> Technical Support >> Moving beams and joists with grids
Wed, Mar 2, 2011 at 8:03:39 AM | Moving beams and joists with grids
mccoolj
Is it possible to have the beams along a grid move with the grid and have the joists in the adjacent bays shorten and lengthen as needed to maintain their original relationship? I have several grids that have changed after review, and while the columns have a "move with grids" checkbox in the properties and automatically adjust, the beams and joists are left where they were. It seems like there would be some parameter for tying those together so I don't have to manually move all of these beams a few inches, then manually shorten half the joists a few inches and manually lengthen the other half. What am I missing?
Jason
Wed, Mar 2, 2011 at 11:56:25 AM | Moving beams and joists with grids
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Just align and lock the beams to the grid lines.
The joists should adapt if the beam moves depending on how you placed the joists.
Using a beam system would help but not required.
Sloping joists to the roof deck
Mon, Apr 4, 2016 at 11:21:15 AM
Joists and Beams show up wrong on model OR sheet.
Wed, Jan 19, 2011 at 2:25:33 PM
Floor Joists
Tue, Apr 1, 2008 at 1:53:41 PM
Beams that are copied are invisible, while beams placed can be seen??
Sat, Jan 20, 2007 at 9:53:43 AM
turn off Auto-detect Adjustment of wood beams?
Tue, Sep 2, 2014 at 4:28:15 PM
Page generation time: 1.1176
