Forums >> Revit Building >> Technical Support >> molding onto curved ceiling
Mon, Feb 28, 2011 at 3:06:30 PM | molding onto curved ceiling
sroreilly
I've created arches by modeling-in-place a solid extrusion for an archway.
Now I need to apply molding on the ceiling face, & am attempting different ways to go about it, but nothing has worked. I've got the molding on the side walls, but lose them when attempting to do the same to the ceiling while working in 3D.
I've attached a picture.
Anyone out there with helpful hints?
Susan
Mon, Feb 28, 2011 at 3:06:58 PM | molding onto curved ceiling
sroreilly
whoops... using R2011
Mon, Feb 28, 2011 at 3:52:15 PM | molding onto curved ceiling
pchan
pchan Avatar
5 Stars: 5 Votes
Susan,
Like i mentioned on other thread, i think the effective way is to model an in-place molding (although I would tackle it by using a loaded family, in this case, you only have to do it once)
The key is to set up a workplane first before you start to model the in-place molding under the curve ceiling
Mon, Feb 28, 2011 at 3:56:15 PM | molding onto curved ceiling
sroreilly
I think that is my problem....
The work plane.
I guess I forgot how to make a curved one!
Tue, Mar 1, 2011 at 10:36:21 AM | molding onto curved ceiling
sroreilly
Nope. Can't seem to get a reference plane to curve....
Any hints here?
Tue, Mar 1, 2011 at 10:47:18 AM | molding onto curved ceiling
pchan
pchan Avatar
5 Stars: 5 Votes
I don't mean to create curve reference plane, I meant to say to set up a ref plane adjacent to the curve ceiling and use it as a work plane.
I am kind of tied up now but will likely to upload something later on.
Philip
Tue, Mar 1, 2011 at 11:37:07 AM | molding onto curved ceiling
julius071
Can't you just create a profile family, use model in-place, use sweep, and use pick lines, and use pick 3D lines? I did it in one of my project recently when I had a curve wall going up to a curved roof.
Revit Architecture 2011 Certified Professional
Tue, Mar 1, 2011 at 11:50:00 AM | molding onto curved ceiling
sroreilly
Thank you both!
I think that I was over-thinking this... and adding in an extra step. What you described is likely what I've already done, I'm just trying to complicate my work experience!
Ta!
S.
Tue, Mar 1, 2011 at 12:16:25 PM | molding onto curved ceiling
pchan
pchan Avatar
5 Stars: 5 Votes
Philip
Tue, Mar 1, 2011 at 2:44:59 PM | molding onto curved ceiling
sroreilly
Nope. Can't make it work.
I can't pick the 3D  face (which is curved). Setting the sweep path along the reference plane which is parallel to my curved surface doesn't work either.
There must be another option?
Tue, Mar 1, 2011 at 3:21:05 PM | molding onto curved ceiling
#11
pchan
pchan Avatar
5 Stars: 5 Votes
Did you mean this is what you want to do?
You have to do it as a separate piece, the hozs are done by sweep picking 3D edge.
and then vertical can be either extrusion/sweep and use join geometry afterward
HTH
Philip
Tue, Mar 1, 2011 at 4:17:35 PM | molding onto curved ceiling
#12
sroreilly
That's EXACTLY what I'm after... wow.
Thank you SO MUCH.... I ought to be able to figure it out now.
You're a god-send!
Susan
Tue, Mar 1, 2011 at 4:27:28 PM | molding onto curved ceiling
#13
pchan
pchan Avatar
5 Stars: 5 Votes
You are welcome
Tue, Mar 1, 2011 at 4:38:12 PM | molding onto curved ceiling
#14
sroreilly
Okay, well.... I spoke too soon.
I want to get the vertical bits 2" from the ends.
I've got the horizontals in, the verticals in, but can't get them to join geometry.
I bet it has something to do with my vertical placements? If they don't all line up perfectly on the curve, they won't join?
(I really like to know the reason something does/doesn't work, so that I can figure these things out eventually! Is there a good book about these intricate little tricks????)
Tue, Mar 1, 2011 at 4:51:32 PM | molding onto curved ceiling
#15
pchan
pchan Avatar
5 Stars: 5 Votes
You are correct.
IN your case, I'd say it takes a bit of trial and error to make sure the hoz and vert lined on the same plane (think of it in reality of how the molding would be done) and you should be able to join them together.
lots of time, think of what you are modeling related to how it will be constructed in real life, then try to use the same concept to apply to your model and it will work.
Philip
wall molding in revit 2010
Wed, Apr 7, 2010 at 9:35:33 PM
Wall and Ceiling Issues
Tue, Jan 20, 2009 at 7:50:47 PM
recessed Lighting for a curved ceiling or roof ceiling?
Fri, Jun 27, 2008 at 11:06:24 AM
Curved Ceiling lights come in upside down
Thu, May 14, 2015 at 12:57:27 PM
Curved ceiling plane?
Sat, Oct 30, 2010 at 12:01:10 PM
Page generation time: 1.6729
