10 Users Online (8 Members):
Forums >> Revit Systems >> Technical Support >> Scheduling shared parameters
2 Posts No Rating |
Hi, I created a family for the beams that I'm using (generic family template), and have a shared parameter for Length. I didn't use the structural framing template because it is too smart for what I need to do and that actually makes it inflexible (I tried it). I also have some beams that are the standard families that come with Revit. My problem is that when I schedule all the beams together I have two different "Length" fields (the one that comes with Revit and the one I created). If I use a line based generic family for my beam, the Length appears as one field (good) but I don't want to use line based because then the beams snap together when they're very close. Help please? Where are the Shared parameters .txt files that come with Revit usually located?
Door parameters not scheduling or tagging in double door. |
Mon, Sep 26, 2011 at 3:29:50 PM
Scheduling shared parameters of nested famiies? |
Sun, Apr 26, 2009 at 1:56:12 PM
Shared Parameters |
Thu, Feb 9, 2006 at 1:41:58 PM
Doors that won't schdule |
Mon, Jul 29, 2013 at 4:21:48 PM
Shared or Project Parameters? |
Tue, Jan 19, 2010 at 7:01:11 PM
