Forums >> Revit Building >> Technical Support >> Views deleted!!
Mon, Feb 28, 2011 at 3:01:28 AM | Views deleted!!
mickc55
3 Stars: 2 Votes
Hi Guys!
We finished our model split on Friday. We found on Monday morning that we had views deleted that where no where near the area of split.
These include plans and 3D Views. I thought I may have lost only detail views or callout views. I didnt realise the 3D views and other plans would be deleted. Any ideas why this is happening???
Any help appreciated!
Michael
Be brilliant,
Michael
Mon, Feb 28, 2011 at 4:17:04 AM | Views deleted!!
4 Stars: 205 Votes
Revit does not erase (delete) views without a direct interference of the user Winking
Mon, Feb 28, 2011 at 6:47:56 AM | Views deleted!!
What do you mean by split?
Mon, Feb 28, 2011 at 6:59:53 AM | Views deleted!!
mickc55
3 Stars: 2 Votes
 As you can see from the link below, we cut,divided,serparated, partitioned the north pir from the main file using revit links.
http://www.osl.no/osl/micro/T2
We solved it ourselves, the problem was that when we deleted views that were not relevant to that area in the pir file, it gave no warning that additional views (importnat ones) would be deleted also.
Cheers,
Michael
P-S thanks for the ''constructive'' help typhoon Winking
Be brilliant,
Michael
Tue, Mar 1, 2011 at 3:36:39 AM | Views deleted!!
mickc55
3 Stars: 2 Votes
Hi Guys!
Is there any way to transfer/copy views between projects?
Thanks,
Michael
Be brilliant,
Michael
Mon, Apr 11, 2011 at 2:44:15 PM | Views deleted!!
dfitzladdy
5 Stars: 3 Votes
I actually just had this problem.  I was editing a form in one elevation view.  For some reason, when I finished my sketch, then clicked "finish family" it told me that another completely unrelated form needed to be edited, although my only option was to click "delete item".  It was small enough that I just clicked "delete item" with plans to redo it, but then I suddenly was taken to a different elevation view.  Then, i discovered that not only were the forms deleted, the elevation that i was just in was deleted, in fact all but one of my 4 cardinal elevations were deleted, AND MY FLOOR PLAN was somehow deleted.  And, I can't undo. I had to close the project and open up an older saved version.  So, it seems that Revit does spontaneously delete views.  Very very very weird.  I've worked in revit for 4 years and I've never had it do this.
I accidentally deleted my elevation views.. help please
Sun, Oct 22, 2006 at 8:41:23 AM
Trash Folder for deleted views
Mon, May 14, 2007 at 8:04:31 AM
Views from project/sheet have disappeared
Fri, May 31, 2013 at 11:22:42 AM
How to delete unused views
Fri, Jan 26, 2018 at 1:19:17 PM
Multiple Views Deleted in Central File - Please Help!
Fri, Apr 1, 2011 at 4:26:18 PM
Page generation time: 2.1343
