Forums >> Revit Building >> Technical Support >> View Template Object Visibility Problem
Sat, Feb 26, 2011 at 2:43:57 PM | View Template Object Visibility Problem
MYoung
MYoung Avatar
Revit 2011
Hi, I have moderate experience with V Templates, but can't figure out an issue.   On level 1, when I apply the default revit "site plan" template, topography and other misc items show up, when for some reason if I toggle 'detail level' from coarse to medium or fine, my walls remain coarse, but in the template, detail level for walls is "by view".
Likewise, if I apply the default 'architectural plan' template, topography turns off... but its checked on in the View Template! and when I go to Visibility Graphics topography is turned on in the view.  Why???
There are no elements hidden in view, phases, or anything convoluted.  This is a simple house floor plan with View Template problems I've never seen.
Ideas?
Sat, Feb 26, 2011 at 2:53:16 PM | View Template Object Visibility Problem
MYoung
MYoung Avatar
note: solved the topography problem (view range - I'm an idiot), but I still don't understand why the wall detail level cannot be changed.
Hidden Object comes back after changing View Template
Wed, Apr 19, 2017 at 12:24:45 PM
Locking Worksets Visibility
Fri, Nov 25, 2016 at 12:00:04 PM
Mon, Nov 18, 2013 at 3:09:54 AM
View Template Difficulty
Wed, Feb 19, 2014 at 9:53:18 AM
Parts visibility not overridden by V&G in view template
Thu, Oct 17, 2019 at 10:10:38 AM
Page generation time: 1.9543
