Forums >> Community >> Newbies >> Wall siding mismatch
Fri, Feb 25, 2011 at 5:01:26 PM | Wall siding mismatch
mcescher
Hello All,
This is my first post, but I am not new here.  I have been reading posts for a long time.
As always, I started my research by reading, but could not locate any answer.  So, I decided to ask:
Attached images tell the story better.  It is a residential setting with a kitchen nook on the first floor.  But the second floor, that nook becomes a flat wall.  When create another wall on top of the nook, exterior siding does not align.
What could be the problem and how can I correct that?
Thanks in advance.
Best,
Sat, Feb 26, 2011 at 3:32:55 AM | Wall siding mismatch
4 Stars: 205 Votes
Is that a "Model Pattern"? if Yes, did you try the "Align" tool?
Sat, Feb 26, 2011 at 1:49:16 PM | Wall siding mismatch
sroreilly
I don't know a lot, but I had this same problem at work yesterday.
I found that the walls that looked mis-aligned on the outside were actually just a tiny bit out of alignment in plan view. I deleted the offending wall, then redrew it, making sure that the  location lines that I was using to draw the wall lined up, then joined the walls. Another time, I also tried using the "align" tool which worked as well, and saved some steps.
This worked for me....  Maybe yours is the same problem?
S.
Sun, Feb 27, 2011 at 3:44:57 PM | Wall siding mismatch
mcescher
Thank you all for your kind replies.
As you (sroreilly) mentioned, I solved the problem by deleting the wall and redrawing the whole wall.  However, instead of splitting the wall, I created an opening and placed the nook walls there.
Problem solved at this moment.
We'll see.
Wall Sweep/Siding
Sun, Feb 17, 2008 at 12:11:00 PM
Exterior siding below wall level
Wed, Feb 17, 2010 at 3:37:03 PM
creating brick and vinyl siding on an exterior wall.
Tue, Feb 5, 2008 at 3:08:52 PM
Siding Sweep Return
Sun, Oct 30, 2011 at 5:57:53 AM
Walls with siding
Tue, Feb 28, 2006 at 5:21:50 PM
Page generation time: 1.4388
