14 Users Online (12 Members):
Forums >> Revit Building >> Technical Support >> Glass is opaque when cut by Section Box
27 Posts No Rating |
I have a family that has transparent glass to cover seating in an auditorium. And it looks great in 3D view with the realistic setting except that where it is cut by the section box it is solid gray and opaque. What setting am I missing. Thanks. I am using Revit MEP 2011
16 Posts No Rating |
hmmm. well, i've never used revit mep ever, but im pretty sure a lot of these visibility settings are the same have you tried hitting VG (visibility graphics override) and checking to make sure that the cut pattern isn't set to something different for the glass? what kind of an element do you have the glass modeled as?
The glass is in a specialty equipment family. I have tried changing the cut pattern in the materials box as well as the VG box.
ah i see. well, the only other thing that comes to mind is maybe there is a construction phase graphics override. but i doubt it... sorry i couldnt help more
That's okay. Thanks for trying. It may not actually be possible either.
Glass is clear but when rendering it is Opaque |
Mon, Feb 6, 2012 at 8:38:07 AM
Section box in Section?? |
Sat, Dec 10, 2011 at 10:23:01 PM
13
Transparency of glass windows in 3d views |
Wed, Aug 5, 2009 at 10:43:37 AM
Problem with opaque text showing transparent |
Mon, Feb 24, 2014 at 9:20:10 AM
Columns not being cut by section box |
Thu, Jul 15, 2010 at 9:38:14 AM
