Forums >> Revit Building >> Technical Support >> Can't place column on upper floors
Fri, Feb 25, 2011 at 12:42:33 PM | Can't place column on upper floors
Elway
I am using Revit Arch 2011. I'm trying to place an architectural column on the second floor but it is automatically placed on the first floor, regardless of whether or not I set its base level to "floor 2". Anyone have any thoughts on why this is the case?
Thanks!
Fri, Feb 25, 2011 at 1:00:03 PM | Can't place column on upper floors
cdfrantzis
have you checked the top and bottom offsets? if there is a 10 foot gap between the first and second floors, and you change the base level but it keeps a -10' offset, itll be in the same location.
Fri, Feb 25, 2011 at 1:03:12 PM | Can't place column on upper floors
Elway
Both top and bottom offsets are set to 0' - 0"...any other thoughts??
Fri, Feb 25, 2011 at 1:10:39 PM | Can't place column on upper floors
cdfrantzis
interesting... what happens if you change the bottom offset to the height difference between the floors? does anything change?
Fri, Feb 25, 2011 at 1:12:33 PM | Can't place column on upper floors
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Where is the level above level two?
Are you sure it's an 'architectural column?
How are you constraining the top and bottom?
Give us a screen capture before you actually place the column.
ALT-PRTSC or Snip tool in Windows 7
Like attached.
Fri, Feb 25, 2011 at 1:46:28 PM | Can't place column on upper floors
Elway
Changing the offset doesn't do anything...it's as though it's constained.
And as far as I know, it's not a structural column. Is there any way I can check that? and I've attached a print screen image.
Thanks!
Fri, Feb 25, 2011 at 2:27:00 PM | Can't place column on upper floors
cdfrantzis
If changing the offset doesn't do anything, that means you do have some constraints set.Although I cannot tell too much from the printscreen, I do see that you have the column at a set height (9') rather than having it be from level to level. Also, it seems as though the column is constrained to Truss B/8 which you can change from the modify - place column toolbar.
This said, I do not see where your column actually is in the printscreen; i see walls but no columns.
Fri, Feb 25, 2011 at 2:44:17 PM | Can't place column on upper floors
Elway
I've attached another print screen with a column placed. Additionally, I attached a section of that placed column. You can see how it's on the first floor, but extended up to the Truss Bearing Level. It doesn't matter if I have it set to Level 1, 2, 3, etc... it always is placed on the first floor. But the height depends on the level/height I have set. Is there any way I can "edit family" and remove any constraints that may be on the column?
Can't place some components without creating floors (REVIT Architecture 2013)
Fri, Dec 14, 2012 at 2:49:55 AM
Replicating floors and everythingon them
Sat, Apr 21, 2012 at 5:56:31 AM
Visibility graphics of a structural column
Mon, Aug 16, 2010 at 8:21:00 AM
Adding a floor around precast columns
Wed, Sep 21, 2005 at 3:37:50 PM
How to see the upper floor (beams,floors) in plan view?
Tue, Jun 14, 2005 at 4:37:20 AM
Page generation time: 0.5546
