Forums >> General Discussion >> Revit Project Management >> Workplane issue
Thu, Feb 24, 2011 at 5:53:11 AM | Workplane issue
Vpokunoff
Hey,
I have a door panel with a swing. So I can move the door in 3d view. The door panel is attached to a reference line.
As you can see from the attachement, I want to add a lower panel to a door ( It has to move with the door as well, when I change the angle). Unfortunately, Im not able to get the panel close to the door.
Can anybody suggest me, what am I doing wrong?
 Regards,
Fri, Feb 25, 2011 at 3:46:07 AM | Workplane issue
4 Stars: 205 Votes
Before you create that panel select the work plane of that "reference Line", then create the panel, dimension and LOCK it or create a parameter for that distance.
Fri, Feb 25, 2011 at 3:57:48 AM | Workplane issue
Vpokunoff
Two days of trial and error but I finally figured it out.
I was choosing the wrong workplane all the time.
Now the lower panel of the door is a separate piece and moves together with the door panel.
Now I am able to attach all the neccessary elements to a door panel.
Furthermore, I did not know anything about workplanes before, but now I have a slight understanding of them.
Creating a new families is still a problem due to the constraints relationship problems.
Regards,
V
Close disscussion
Workplanes issue: Unable to dissassociate objects and masses from workplane
Tue, Dec 2, 2008 at 3:09:56 PM
Adjusting the building workplane so that it orients to site bearing.
Tue, Aug 5, 2014 at 7:23:49 AM
Orthogonal project to workplane defined by Reference Line
Fri, Feb 12, 2016 at 3:52:40 PM
Workplane "viewer" what is it??
Tue, Jun 26, 2012 at 1:33:52 PM
How to bend my workplane to fit curtain surface... ?
Tue, Feb 24, 2009 at 8:05:40 AM
Page generation time: 0.2703
