Forums >> Revit Building >> Technical Support >> Element in design option
Wed, Feb 23, 2011 at 10:28:36 AM | Element in design option
nirim
5 Stars: 12 Votes
hi there
How to show on one design option a door in a wall and on the same wall but in second design option to show the wall without the door? And is there way to move back element from one design option to another?
nirim
Wed, Feb 23, 2011 at 10:31:47 AM | Element in design option
Hosted elements must have their host in that option.  Thaty means you must have the wall in question in both options, one without the door and one with.
Wed, Feb 23, 2011 at 11:04:31 AM | Element in design option
nirim
5 Stars: 12 Votes
How do you mean? If I am in option two I can’t delete the door (it is in gray).
Wed, Feb 23, 2011 at 11:11:52 AM | Element in design option
You can control what your view shows through VG.  I suggest yout set up multiple views of each DO, then in VG, change the DO settings from automatic to the individual DO for that view.
Then, in DO A, you have the blank wall and in DO B, you have the wall with the door.
NOTE:  To edit items in a design option, you must be working in that design option.
Edited on: Wed, Feb 23, 2011 at 11:12:38 AM
Railing wont host to stair created in design option
Mon, Oct 24, 2011 at 3:54:39 PM
Cleaning Up Design Option Elements with Main Model Elements
Wed, Jun 17, 2015 at 1:38:27 PM
Design Option Issue - walls in 1 design option cutting thru a 2nd option
Thu, Oct 21, 2010 at 11:55:04 AM
Design Option view setting
Fri, May 16, 2014 at 8:02:11 PM
Design Options - black hole.
Wed, Feb 14, 2007 at 12:54:40 PM
Page generation time: 0.2842
