28 Users Online (26 Members):
Forums >> Revit Building >> Technical Support >> Glass Block Wall
1 Posts No Rating |
I am trying to create a glass block wall that is curved for an office building. Does anyone know the best way to go about accomplishing this? Thanks!
Copy your standard block wall and assign it your material that is similar to glass but has a masonry surface pattern. Then use an arc to place this wall.
other alternative is to use curtain wall, create a custom curtain panel that mimic the glass block and use it in curtain wall panel inside the project. set none to all the vertical and hoz mullion. if you don't want to create custom panel, then duplicate your system panel and change the dimension that mimic the glass block and use it of course make sure the material is assign to glass block like material
Glass Block Wall |
Wed, Apr 20, 2005 at 12:04:41 AM
How to create a Glass Block Wall? |
Thu, Mar 23, 2017 at 6:51:59 PM
13
Glass block |
Sun, Jun 4, 2006 at 12:38:25 PM
glass block wall |
Tue, Mar 2, 2004 at 9:49:52 PM
Glass block surface patterns: how to adjust? |
Tue, Mar 27, 2007 at 10:56:01 AM
