Forums >> Revit Building >> Technical Support >> Soffit face wall join issue
Wed, Feb 23, 2011 at 10:09:08 AM | Soffit face wall join issue
altlore1
1 Stars: 1 Votes
Hello, I have created a 5/8" wall face for a soffit ceiling (works fine) but the wall face will not join with the two walls that meet up with it. Every time I attempt, it shoots past the corner and gives me an error if I trim or set it just short. Wall joins & Trim/extend function do not work.  Any suggestions?
Wed, Feb 23, 2011 at 1:42:34 PM | Soffit face wall join issue
pchan
pchan Avatar
5 Stars: 5 Votes
I would suggest to add a "stud" layer to your soffit wall so you should be able to have a clean join
Wed, Feb 23, 2011 at 3:33:56 PM | Soffit face wall join issue
altlore1
1 Stars: 1 Votes
The gyp was placed on the stud layer and is listed as structure but still will not join.
Wed, Feb 23, 2011 at 4:13:14 PM | Soffit face wall join issue
pchan
pchan Avatar
5 Stars: 5 Votes
I think the problem is that when u change the layer function to structure, it will not clean it up with the gup bd at the corner.
i tried it with the  standard soffit wall type and it works fine to me
See attached
Recessed lighting in soffit?
Mon, Nov 15, 2010 at 10:32:36 AM
Disallow wall join of a mid-end face
Mon, Feb 11, 2008 at 5:54:01 PM
Revit 2015 join wall to underside of floor and ceiling issue
Wed, Mar 2, 2016 at 2:59:03 PM
Column Join issue
Wed, Oct 11, 2017 at 10:10:15 PM
Roof by face, wall by face clean up
Tue, May 29, 2012 at 4:57:43 AM
Page generation time: 3.0372
