Forums >> Revit Structure >> Technical Support >> Newly created column family not inserting correctly
Tue, Feb 22, 2011 at 2:09:56 AM | Newly created column family not inserting correctly
Rusty55
I have created a new column family (my first experience of family creation/modification), but when I insert it into the model it will not adhere to the base level and top level parameters.  Instead, it will only insertion of the component on one given floor and then when you try to modify it using the constraints it either does not change, or jumps to a level that is unspecified.  It is also possible to set the base level above that of the top level.  I constrained the lower and upper reference planes when i created it.
 I have attached the family file.
Tue, Feb 22, 2011 at 9:49:42 AM | Newly created column family not inserting correctly
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Personally, I would not create a new column or beam famiy from scratch.
There's a little bit of magic going on between the reference lines, reference planes and the column shape.
I would open and existing column family, rename it, make the changes and save it. (and make as few changes as possible).
Set the base level above the top level ??
What? not that I am aware of.
Tue, Feb 22, 2011 at 8:03:19 PM | Newly created column family not inserting correctly
Rusty55
Thanks dgcad, I will give that a try.
 I thought I would try setting the properties of the column to something impossible to see how bad the reference planes problem was, and sure enough it didn't even recognise the impossibility of what I was asking it.
Creating and inserting family types
Mon, Sep 23, 2013 at 4:23:25 PM
Column Join issue
Wed, Oct 11, 2017 at 10:10:15 PM
Family Help - Inserting into model without distorting other members
Mon, Mar 19, 2012 at 10:25:48 AM
Column Capitals
Wed, Sep 18, 2019 at 8:39:07 AM
Created channel column shows off its structural axis (physical appart blue line)
Thu, Jun 27, 2013 at 5:46:12 AM
Page generation time: 1.5621
