Forums >> Revit Building >> Technical Support >> Rendering problem - Out of ideas!
Mon, Feb 21, 2011 at 12:38:37 PM | Rendering problem - Out of ideas!
maxnaoki
Ever since i got a new pc in september last year, i havnt been able to render on revit 2011, or should i say, finish a render
what it does is random, it will not render on HIGH or BEST settings (printer or screen resolution). it will simply do a range from 10-99% and just stop. it will be at 40% for example, then just go to 100% and stop rendering.
just a quick spec for u on my system
win7 ultimate 64bit
Ram - 4x2gb sticks (8gb total)
CPU - i5-760 OC 4.1ghz (cooled)
GPU - Radeon 5850
ok so thats out of the way. i have run memory tests on mem86+ and no problems. 27 passes 0 errors. people say you need more RAM to render on 64bit, maybe, but 8gb is surely enough. and to put it in perspective. i had to use my laptop with 2gb of ram to render a 5000x2000 300dpi BEST settings to get my work done. albeit it took 2 days and 18hours. but it did NOT crash.
 can anyone hazard a guess at why my revit on the pc is not rendering?
Mon, Feb 21, 2011 at 5:31:06 PM | Rendering problem - Out of ideas!
lunchtrayrider
3.5 Stars: 7 Votes
possibly the overclock.  Revit won't deal well with any errors from an overclock.
I like scooters. and motorcycles.
Mon, Feb 21, 2011 at 7:57:02 PM | Rendering problem - Out of ideas!
maxnaoki
i had a feeling it could just be from overclocking, however, i cannot afford to drop the speed as revit is the only thing not working on the pc (when rendering anyway) nooo ._.
and i thought overclocking would actually help it render..
Tue, Feb 22, 2011 at 9:42:15 AM | Rendering problem - Out of ideas!
lunchtrayrider
3.5 Stars: 7 Votes
I you're crashing during rendering you could also be corrupting files.  That isn't going to help anything go faster.
Tue, Feb 22, 2011 at 2:40:13 PM | Rendering problem - Out of ideas!
coreed
coreed Avatar
4 Stars: 16 Votes
atleast see if that solves the problem.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Sat, Jul 13, 2013 at 11:47:50 AM | Rendering problem - Out of ideas!
kansasdesign
2 Stars: 1 Votes
Hate to reopen an old thread but I am having a very similar issue with revit 2013 on an 17 O.C.'d to 4.8ghz. Rendering atarts for about 2 min then just skips ups to 100% It is maddening. Did removing the overclock help? Or does anyone have any ideas on how to solve this problem?!
I have stress tested all of the hardware (memtest86, intel burn test, etc) all passed.
HELP!
Thanks!
problem rendering in 2010
Sat, Apr 24, 2010 at 2:38:51 PM
Revit 2009 Rendering Problem(Black screen) [ 1 2 ]
Mon, Apr 1, 2013 at 2:45:28 PM
27
Rendering Problem
Wed, Feb 6, 2013 at 1:41:48 PM
Rendering... Block Walls and Floor
Wed, Apr 8, 2009 at 8:28:39 AM
Problem while rendering
Tue, Feb 12, 2013 at 1:37:23 AM
Page generation time: 2.2490
