Forums >> Revit Building >> Technical Support >> grid layout
Mon, Feb 21, 2011 at 12:15:45 AM | grid layout
diesellam
How can you make the same grid layout applied on every level?  Like if I make one change to the grid line, the same change will apply for the rest of the floors?
Mon, Feb 21, 2011 at 1:30:34 AM | grid layout
julius071
I created grid lines in Revit 2011 in any floor plan and it appears in every one and the grids are links in floor plan views.
Revit Architecture 2011 Certified Professional
Mon, Feb 21, 2011 at 7:20:18 AM | grid layout
palladio1234
5 Stars: 3 Votes
use the grid command "GR" amd place a grid line.  it will move in all levels. try and see
Mon, Feb 21, 2011 at 7:40:24 AM | grid layout
diesellam,
You need a better understanding of datum's.  Start by reading theis chapter in your HELP: Datum Extents and Visibility.  There are 2D settings and 3D settings for datum's- this chapter will tell you how to turn a 2D setting into a3D: Propagating 2D Datum Extents
changing grid lines angle - walls are detached
Fri, Apr 20, 2007 at 6:29:43 PM
Number of items in grid array
Fri, Sep 24, 2010 at 6:34:27 PM
Ceiling Grid
Wed, Mar 16, 2011 at 3:15:50 PM
How do you change the default grid layout when modeling ceilings?
Tue, Feb 6, 2018 at 10:30:49 AM
Ceiling grid visibility
Mon, Oct 13, 2008 at 9:10:29 AM
Page generation time: 0.1034
