Forums >> Revit Building >> Technical Support >> External Fire Stairs
Tue, Nov 8, 2005 at 6:28:35 AM | External Fire Stairs
Nathan
4.5 Stars: 3 Votes
Hi I am trying to create an external flight of stairs running up the side of a building. The stairs have risers straight up and then a platform before the fire escape door. When I design the stairs however with the risers going straight up there is a gap right at the top where the platform should be. If I place another riser parallel to the fire escape at the top then this overcomes the problem but is not an accurate sketch of the stairs. Is there anyway to have a straight set of risers only with a platform at the top? Thanks in advance
Tue, Nov 8, 2005 at 7:26:52 AM | RE: External Fire Stairs
Will9000
4 Stars: 5 Votes
Have you thought of constructing the landing using the floor tool?
Tue, Nov 8, 2005 at 9:47:41 AM | RE: External Fire Stairs
Nathan
4.5 Stars: 3 Votes
I cant do that because you need to pick by walls and there are no walls to pick as it is an external fire escape
Tue, Nov 8, 2005 at 11:01:44 AM | RE: External Fire Stairs
Will9000
4 Stars: 5 Votes
instead of pick walls, sketch using the lines
Fire-tags
Thu, Apr 6, 2006 at 2:21:21 AM
formulas for fire rating.
Tue, Oct 14, 2008 at 8:24:03 AM
Fire Rated Walls Plan
Sat, Sep 8, 2012 at 11:31:19 PM
Louvers/External Shading
Mon, Jan 8, 2007 at 11:13:08 AM
Fire extinguishers
Mon, Mar 22, 2010 at 11:13:36 AM
Page generation time: 1.4152
