27 Users Online (25 Members):
Forums >> Revit Building >> Technical Support >> Brick Wall Recesses - How to properly model?
Good morning all, We've just started model a current project, full brick commercial building, the architect has about 3 different brick face recessess. aka, the nominal air space is being fluctuated. Now, I know there are many ways to do such a thing, but is there a best practice? Using curtain walls with various profiles and "cuts". Stacked walls? Void families? For example, for the MAIN facade we're using a Jumbo brick that has a 3" air space, next to that a standard brick with a 2" air space, and under windows in that 2" area, we have standard brick with a 1" air space. Acad representation, figured an image would clear this up a bit.
Because the air spaces are different, I would probably model as sperate walls and sketch their wall profiles but that could be a pain. Another choice would be to do the whole wall as std brick, 2" air then add voids to cut face areas back to the 1" air depth and add a thin wall with the jumbo brick with a sketch wall profile. Anyway you do this, it will be a problem.
Thanks for the response! Between the time I posted and now, I have been messing around with many different styles. The easiest way I've found, is to simply make a stacked wall 3" air space and 2" stacks (since thats the "core" of the building) and to simple add a 1" (or 2" air space wall where the instance occurs, and cut the stacked wall with it. It actually turned out pretty nice, as for the windows and their situation, I haven't figured that out as of yet.
recesses in slabs |
Thu, Sep 29, 2005 at 3:33:42 AM
Exterior Wall Recesses |
Mon, Jan 9, 2006 at 6:50:58 PM
Wall Recesses |
Fri, Jul 9, 2010 at 9:49:00 AM
Adjust Brick veener to move down agianst the brick ledge. |
Thu, Jul 26, 2018 at 2:23:13 PM
brick sill below window on brick wall |
Thu, Mar 13, 2008 at 6:10:23 PM
