18 Users Online (16 Members):
Forums >> Revit Building >> Technical Support >> Leader length on Tags
7 Posts No Rating |
Is there a way to control the length of a leader when inserting tags? I am using a wall tag, when I insert the tag, it is too far from the wall. The only way I can control the length of the leader is to turn off the leader, move the tag closer to the wall, then turn the leader back on. Yes, it works, but seems time consuming considering the number of walls i need to tag. Thanks for the help.
That options bar will get you every time if you don't look at it. When you start a tag, there is a switch on the options bar to have a leader or not. With a leder, there is also a length option. Got it?
Oh my. The simple things in life. Thank you WWHub
Leaders on keynote tags |
Mon, Mar 27, 2006 at 2:43:01 PM
Revit Dimension Straight Leader Line with Controllable Node at Elbow |
Thu, Jul 12, 2018 at 12:32:47 PM
Elevation Tag - Leader Problem |
Thu, May 17, 2012 at 5:48:20 PM
How tags attach to elements |
Tue, Jul 22, 2008 at 11:20:12 AM
Leader Line Control with Wall Tags |
Thu, Oct 29, 2009 at 11:39:29 AM
