27 Users Online (25 Members):
Forums >> Revit Building >> Technical Support >> conceptual mass -newbie to that
I did my plan with straight walls in a revit family and its done. now I may want to do teh external walls curved.. and I tried in conceptual mass but is there any way to adjust there the already done plan(family) in scale aswell so that mass of shape i will make on conceptual massing is accurate shape and suits with current plan?and then jsut play with curve of walls also can you make the conceptual mass into building or its just for creating ideas?. if not how can i make curved walls?:S thanks alot for reading
4 Posts No Rating |
conceptual mass is just a tool for creating massing (form) which you can load to your project (rvt file) for further documentation. you dont do anything in the conceptual mass other than creating a mass of course. if you want to draw a curve wall (not a slanting wall) just draw a normal wall but instead of a default line... choose either of the 4 types of arc in the draw panel before you actually draw the wall in your view. hope this helps
no when I say curved wall I mean as not vertical straight to ground, like like cirved on vertical dimension... but im not doing that now ,its too complicated..thanks for the reply
conceptual mass problem |
Fri, Jan 13, 2012 at 4:02:05 PM
Scaling Conceptual Mass |
Mon, Oct 11, 2010 at 7:34:51 AM
Update Structural Framing with Updated Conceptual Mass? |
Thu, Mar 12, 2015 at 6:54:55 PM
Conceptual Mass: Revit Architecture 2012 (Trial V.) |
Mon, Jun 30, 2014 at 7:20:05 AM
Sharing Coordinates Conceptual Mass Environment and Project Environment |
Sat, Nov 16, 2013 at 10:14:00 AM
