18 Users Online (16 Members):
Forums >> Revit Structure >> Technical Support >> DLH JOISTS
2 Posts No Rating |
Does anyone have any clue as to how this DLH joist family works? There are 3 adjustable parameters on each end of the joist and the only thing i've figured out is that one of the parameters controls joist seat extention, and one controls the length of the end panel and the last one i think controls the last web member, though i'm not sure on that last one. All the pick points start out on top of each other, so you have to seperate them. The joist seat parameter works the way it's supposed to but if i adjust the end panel parameter then it pulls the drag point away from the original spot and i have to readjust. Now if you adjust the last parameter and pull it past the end panel parameter then it says it can't make DLH joist. Now if you finally by some magic get the one end the way you want it and try to adjust the other end, it messes up the end you fixed. And then you can't even get it to look right in plan. So what is going on, any help would be great.
rendering joists |
Mon, Jun 27, 2005 at 2:07:04 PM
Sloping joists to the roof deck |
Mon, Apr 4, 2016 at 11:21:15 AM
joists |
Thu, Oct 11, 2007 at 4:43:14 PM
JOISTS ON BEAM DISPLAY REPRESENTATION |
Fri, Dec 19, 2008 at 10:38:03 AM
Sloping Bar Joists? |
Thu, May 7, 2009 at 9:41:08 AM
