Forums >> Revit Systems >> Technical Support >> Filters, Fill/Surface Patterns and Halftone or Line Weight?
Thu, Feb 17, 2011 at 4:06:39 PM | Filters, Fill/Surface Patterns and Halftone or Line Weight?
Gyvven
5 Stars: 2 Votes
I've looked through some similar questions but they were a little old, and I'm hoping that things have changed. My question is: Is it possible to halftone patterns? I have some special ductwork that requires it to have a crosshatch pattern but I want it to show as halftone or at least a fine line weight. I tried making it gray and printing with raster instead of vector but that didn't work.
 I lament the old days of AutoCAD where I could make things appear as I wished.
Thu, Feb 17, 2011 at 4:10:29 PM | Filters, Fill/Surface Patterns and Halftone or Line Weight?
Gyvven
5 Stars: 2 Votes
I forgot to mention that I'm using Filters to apply the surface pattern.
Fri, Feb 18, 2011 at 3:11:12 PM | Filters, Fill/Surface Patterns and Halftone or Line Weight?
Gyvven
5 Stars: 2 Votes
Ok, I feel like an idiot. I had it working at some point in the past and then it wasn't and I couldn't figure out why. When I was going through the print setup to print of a half-size I realized that someone had changed the default  'Appearance' > 'Colors' from Grayscale to Black Lines.
Problem solved. Sorry, Revit, it wasn't your fault... this time.
Halftone cut Patterns
Mon, Nov 19, 2012 at 4:05:25 PM
Fill Pattern Weight
Thu, Dec 17, 2009 at 12:03:13 PM
Provide Control of Surface Pattern Line Weight
Tue, Apr 28, 2009 at 7:02:43 AM
SURFACE PATTERN LINE WEIGHT
Fri, Mar 28, 2014 at 2:30:00 PM
Existing Phase Surface Patterns visibility
Tue, Nov 14, 2006 at 6:37:24 PM
Page generation time: 1.8889
