Forums >> Revit Building >> Technical Support >> Moving up Multiple Tower Levels
Thu, Feb 17, 2011 at 2:13:07 PM | Moving up Multiple Tower Levels
MYoung
MYoung Avatar
Hi, I am working on a 44 storey tower, and want to move the top half of the tower (L19+) up by 6", but when I do so I get around 1500 warnings about unjoining / ungrouping, deleting objects etc... all errors which would destroy my unit and core groups.  I tried several methods, selecting everything in 3d, then selecting the levels in elevation and moving them up, but nothing works without massive errors occuring.  I have control of all the elements.
Any ideas?  I'm going crazy.
Thanks, Mike
Thu, Feb 17, 2011 at 3:47:18 PM | Moving up Multiple Tower Levels
In elevations, are you selecting elements to move or are you just moving the level?   Just change the elevation of the level.
Thu, Feb 17, 2011 at 3:55:01 PM | Moving up Multiple Tower Levels
MYoung
MYoung Avatar
If I select all the levels and try and move them up (roughly 25 levels to be moved up 6"Winking, revit wants to delete all my curtainwall.  If I go in an manually adjust each elevation by 6", it works on the top levels coming down, but as soon as I hit a typical level, Revit prompts me to 'fix groups' and subsequently ungroup a ton of stuff.
Multiple Levels..Many Multiple levels..
Fri, Jan 21, 2005 at 7:06:26 PM
Moving Floor Levels Independently
Thu, Feb 25, 2010 at 1:37:17 PM
multistory stairs skiping levels
Sat, Jun 17, 2017 at 6:28:57 AM
What Computer Tower?
Tue, Sep 24, 2024 at 4:46:42 AM
Tower with GlcurseGlazing
Thu, Jan 13, 2005 at 3:05:07 PM
Page generation time: 1.5810
