Forums >> Revit Building >> Technical Support >> Need Help With Links
Wed, Feb 16, 2011 at 3:16:38 PM | Need Help With Links
renderforfun
4.5 Stars: 6 Votes
I have created two files: 1 file is the site and the other file i have modeled my buildings in.  I have inserted my Building model into the site file.  Now my problem is with my railing materials, for some reason I can not change them to black.  In the bldg. model file I have applied the correct material and the railings are black in the file.  Not sure whats going on any ideas would be great. Thank you!
Wed, Feb 16, 2011 at 3:39:20 PM | Need Help With Links
Typically, I want to render from the file that has the correct settings.  So I would link the Site into the building and render from that.
Thu, Feb 17, 2011 at 2:42:14 PM | Need Help With Links
renderforfun
4.5 Stars: 6 Votes
Ummmm that sounds like a work around but I will try it b/c i need to get this done.  I would really like to know what the problem is though.
Thu, Feb 17, 2011 at 3:21:19 PM | Need Help With Links
cadman6735
cadman6735 Avatar
5 Stars: 4 Votes
Make sure the material in your site file matches the material in your building file. (same name and same materials)
Revit, for some reason will, even though you have set the material correctly in the file you modeled your element in, if the materails in the host model have the same name but different material assigned to it, the linked model will take on the material properties of the host model.
But this is just a blind guess and only from my experiance from what you describe
Hope this helps
  • Ability is what you're capable of doing.
  • Motivation determines what you do.
  • Attitude determines how well you do it.
Quote by:  Holtz, Lou
  • Life is all about the attitude
Thu, Feb 17, 2011 at 4:54:08 PM | Need Help With Links
cadman6735
cadman6735 Avatar
5 Stars: 4 Votes
My explanation above if for families not links,
so check your family materials, make sure your project materials match your family materials.
If it still does not work, upload the file.
Trouble converting links to groups
Tue, Oct 25, 2016 at 12:12:21 AM
*URGENT * - Worksets & Links
Mon, Oct 12, 2009 at 5:51:32 PM
Links
Wed, Jul 28, 2010 at 7:07:06 PM
MANAGE LINKS
Tue, Nov 10, 2009 at 7:41:25 AM
Save to Central or Revit Links
Tue, Sep 4, 2007 at 2:56:57 PM
Page generation time: 1.4925
