Forums >> Revit Systems >> Technical Support >> copy/paste components at different levels without loosing the lock with grids
Wed, Feb 16, 2011 at 3:50:00 AM | copy/paste components at different levels without loosing the lock with grids
Emja
Hallo to everybody. I normally have walls, beam, column etc. locked to grids, so that when the architects come with revisions (I work with RST), I can simply move the grids and everything move consequently.
That´s VERY useful! When I work with several levels, I use to complete one floor, copy and paste it in the other levels (then I delete/modify the not-common part as needed).  But then... the walls are not locked anymore to the grids! and it´d take loong time to go inside every single component, allign and than lock it. How do you do that for 20 floors?
I could also apply the revisions in my main floor, repeat the copy/paste in the other floors and edit again the non-common parts...but it takes long time too.
So, I hope there´s a way to copy between levels and still, the locks to the grids are there.
 Thanks for any answer and sorry for my english.
Can't Get Copy Monitor to Work for Grids and Levels
Fri, Feb 21, 2014 at 4:55:28 PM
Lock Columns to Grids
Fri, Nov 2, 2007 at 6:33:27 PM
Aligning grids the same in each level?
Fri, Sep 23, 2005 at 11:13:39 PM
Copy, paste aligned, to level... for parking stripes
Wed, Nov 11, 2009 at 7:32:47 PM
new user - copying grids to other levels
Mon, Dec 6, 2010 at 3:06:35 PM
Page generation time: 2.0600
